TopCat's avatar
TopCat
4 years ago
Solved
Home phone on fibre during power outage
Telus recently 'upgraded' my home phone from copper to fibre using the Alcatel-Lucent ONT. All was well until a power outage occurred in my neighbourhood, and the home phone died (internet too, with ...
  • polecat's avatar
    4 years ago
    TopCat  The ont has no batt copper has voltage on it fiber none. When i put my home phone on fiber  (we had a very bad copper connection for years Every rain storm bad noise)  I asked for a battery backup for the ont and they installed it free. I had no cell phone at the time we have medical conditions.  You need a older phone to use during outages  (push button at the source 10 to 20 $ ).  Cordless will not work the base needs 120 volts.  The router will not work for internet  wifi needs to be plugged into 120 volt. With little phone use backup should last 12 to 36 hours. Regular  generators do not supply a good constant 60 cycle sine wave and will wreck the  ont  router and the tv. Called modafied sine wave  (square wave 60 cycle)  Inverter generators are high in price. You will have to ask for the unit. Polecat
