Dougie65
4 years agoFriendly Neighbour
Help With Pre-Instal
Hello. I’m switching from Shaw to a Telus Wifi 6, Optik TV and home phone. I’d like the modem/wi fi upstairs with just the OTC in the basement. I’m running some Cat6 from the basement to the upstairs...
4 years agoYour best bet is to talk to the installer when on site to see what is feasible without any additional charges. If the installer has to run wiring outside of a standard install, they may charge for it.
The PVR is a set top box and would be attached to a TV and connected to the router either through ethernet or coax depending on the wiring available where the fibre is being installed. The fibre ONT/router is typically going to be installed near where the fibre comes into your residence since the newer units have the ONT and router built into a single fibre connected unit. Wifi6 is a separate module connected by ethernet so it's location is more flexible if you have ethernet run to other areas of the house.
Dougie65
I’m confused, the website says the PVR isn’t a set too box and that all the TV’s use the 4K TV box while the PVR plugs in to the modem
Sent from my iPhone
Sent from my iPhone
