Everlong's avatar
Everlong
Friendly Neighbour
3 years ago
Solved
Firewalla + Fiber + Arcadyan NH20A + WiFi6 over Coax, What to do????????
just like the topic says, just purchased a Firewalla Gold to replace my router. Did not look at the connection of the WIFI AP on the router and just noticed its a coax cable which goes upstairs where...
  • DrPacman's avatar
    3 years ago
    Everlong Wrote: Firewalla + Fiber + Arcadyan NH20A + WiFi6 over Coax
    If I'm gathering correctly, it looks like you may need to invest in a MoCA 2.5 Network Adapter... that will allow to output Ethernet from your Firewalla, connect coax to the output and push that signal up to your wireless access point...
    I believe that what your trying to do, correct?
    If you find a post useful, please give the author a "Solution", or mark as "Kudo", if it solves your problem, thank you very much.
