Everlong
3 years agoFriendly Neighbour
Firewalla + Fiber + Arcadyan NH20A + WiFi6 over Coax, What to do????????
just like the topic says, just purchased a Firewalla Gold to replace my router. Did not look at the connection of the WIFI AP on the router and just noticed its a coax cable which goes upstairs where...
- 3 years ago
Everlong Wrote: Firewalla + Fiber + Arcadyan NH20A + WiFi6 over Coax
If I'm gathering correctly, it looks like you may need to invest in a MoCA 2.5 Network Adapter... that will allow to output Ethernet from your Firewalla, connect coax to the output and push that signal up to your wireless access point...
I believe that what your trying to do, correct?
If you find a post useful, please give the author a "Solution", or mark as "Kudo", if it solves your problem, thank you very much.
DrPacman
3 years agoRockstar
- Everlong3 years agoFriendly Neighbouryes, !!!!!! Thanks!!!! i never knew such thing existed 🙂
