MWH
22 days agoNeighbour
Fire tv Stick HD
Tried the fire stick 4k but doesn't work because its a in house operating system what I found out , can't side load so bought the new fire stick hd wifi 6 , thought what I've read I get Telus TV Plus...
FuzzyLogic
22 days agoSupposedly works if you FireOS 6 or higher. More here:
MWH
21 days agoNeighbour
mine is updated to this version OS 1.1 (1501010006520 ) isn't the sae as my old fire stick because the developers part is sae version as the in house version , might just go to telus because just not working
- FuzzyLogic21 days ago
The new Fire Stick you have doesn't run FireOS but instead uses VegaOS so that won't work. Supposedly these models support FireOS 6 or higher:
Fire TV Stick 4K
Fire TV Stick 4K Max
Fire TV Stick 4K Plus
Fire TV Stick
Fire TV Stick LiteDo you stikk have the Fire TV Stick 4K? If so you can check the version of FireOS:
- Go to Settings on your Fire TV.
- Select My Fire TV.
- Select About.
- Select Check for System Update.
Hopefully you can get it working.- MWH21 days agoNeighbour
lol Amazon gonna get tired of me but it doesn't matter , either I'm gonna get a tv box i guess fro Telus for my upstairs or isn't there other sticks that aren't Amazon that work maybe Roku
