kongaloosh
3 years agoOrganizer
Fibre NH20A port forwarding issues: works for some ports, not for others
I'm trying to port-forward for a valheim server. Ports 2456-2458 computer acting as server has a DHCP reservation server is setup as DMZ firewall is down setup up with a dynamic dns The int...
TheCanadianShield
Really interested as to how you completely disabled the firewall on the NH20A.
I’ve only ever been able to minimize it but never remove it and I’ve seen unverified reports that the TELUS connect app plays a role in completely disabling it as well.
I’m hitting the same challenges as you are and that PF works for ~3 minutes after resetting the device makes me point to something not allowing traffic through the device.
kongaloosh
I actually managed to solve this. In my case, I went through a trial-and-error process adding features in the WAN settings until I got the desired behaviour. In this case, it was all on my end. For people looking at this thread in the future:
I used netcat to open up a listening port on my computer, and then used an online port-checker to see if it could connect to my computer over UDP.
E.g.,
nc -l 2456
When I was relying on the docker container exposing the port, the port-checking tools would list the port as closed. When using netcat, suddenly the port-checkers would report 2456 as open. So, I could tell that the issue was with the docker container, not with my router :S
As for disabling the firewall:
You need to login to your admin panel for the modem: 192.164.1.254. From there, under the network tab you can see the settings for the firewall.
What are the specifics of the PF setup you're working on?
TheCanadianShield wrote:Really interested as to how you completely disabled the firewall on the NH20A.
* I don't use the telus connect app. Instead I log
- TheCanadianShield3 years agoOrganizer
I ask about the firewall because I don't see any option to actually disable it on the NH20A
I know it's something on the NH20A because the SECOND I bypass it (by either moving the SFP back into the T3200 I still have or doing port bridging) everything works without issue.
I'm PF'inbg a bunch of random TCP ports for various apps and again, no issues when using anything other than the NH20A- TheCanadianShield3 years agoOrganizer
So here's where I'm at. My Technicolor NAH (FXA5000) is working.
How? Not entirely sure, but I believe it was an IPv4 firewall issue and not port forwarding that was the culprit. The issue that I was having (and I'll reiterate that this was MY experience) was that the port forward rules were valid and the specific ports themselves WERE open. What I determined was that the IPv4 firewall rule set would never completely set itself to NAT-ONLY. I tried bypassing the NAH, using my T3200M, bridging every single port. Heck, I even borrowed a UDM pro and dropped the GPON SFP into it. All of these worked as expected. The only thing that didn't was running traffic through the NAH in gateway mode where the ports I had forwarded would test as open, however, the traffic wouldn't be visible on the internal network (thank you wireshark). This brought me to concluding there was a firewall/traffic filtering issue at work.My solution? I was able (through friends and people I used to work with) to get in contact with the team that does consumer device testing and pled my case, complete with documentation, Visio diagrams and my hypothesis. I never received a definitive answer, but I left the NAH live for a couple of days, performed a factory reset on the device, and everything worked as expected. I've never received any follow-up comms explaining what changed, if anything, but it does seem to work now.
