kongaloosh
3 years agoOrganizer
Fibre NH20A port forwarding issues: works for some ports, not for others
I'm trying to port-forward for a valheim server. Ports 2456-2458 computer acting as server has a DHCP reservation server is setup as DMZ firewall is down setup up with a dynamic dns The int...
3 years agoHero
In the post I linked you to the solution was to reset to factory defaults and then reboot. It's possible the config is corrupted giving you the odd behavior.
kongaloosh
Factory reset and re-configured the hub. Same behavior: SSH on 22 is fine, 2456-2468 are inaccessible. It’s strange to me, because I wouldn’t expect 2456-2458 to be blocked.
