Titanium's avatar
Titanium
Organizer
4 years ago
Fibre drilling and termination box locations
Telus is installing underground fibre in my area, all the homes have underground utilities and all homes face the street head on.
The homes all have from left to right (coming from the under ground right of way at the street like an upside down "T") Copper, Electricity, Right side *your home* Left side, Gas. Then Copper/Electricity next house, etc.
Based on this I assume with they will install Fibre flow pots so that it will be Fiber/Electric, Home, gas, Fiber/Electric, home gas.
Here's my concern, my siding is brand new and I don't want them installing a new termination box on my house and drilling a hole in the wall on the Left (most visible) side. I'd like to request that my flower pot (and hence my termination box) goes on the Right side by the gas meter, and my Fiber and the Right house neighbors (left Fiber) are in the same area. Is this allowed, picking the side, or is there some rule that says all wire services going to a single home must be on a certain side of a home, even my neighbors fibre is right beside my gas line.
Next. If I can not pick what side I want, can I have them snake the conduit up to my Phone/copper termination box and have them just snake the fiber through that box and into the existing hole in the wall. Essentially reuse the Telephone coppe termination box, there is no technical reason blocking it from being done, epically since the only thing in this box is Telephone (not CATV) and telephone copper is going in the trash anyways.
  • You probably have a copper ethernet line to your home also, along with the phone line, one in the same now I suppose? What side is your homes Electrical Utilities closet on? I assume it's all on the left side? You should be able to have the new fiber line put as close to the ethernet line as possible, I believe they have to terminate it where your electrical/coms/utilities box/closet is. Will it be a unsightly penetrator if it it's right close to the ethernet penetration?
    • Titanium's avatar
      Titanium
      Organizer
      The telephone line (as you said) is actually just a Cat5 ethernet cable that comes in and they use a twisted pairs off of that to make the phone.
      And yes, the Left side of the house has an electric meter, and the phone box.
      "Will it be a unsightly penetrator" yeah it would be. The way the home was set up with the windows, utilities boxes, etc (there's even a small path/hole directly behind the telephone box underneath the siding {you'd never know unless the siding was removed}) was meant for those 2 boxes (electric and phone/cable box) to be there, and nothing else. Place a new box would be tight, unsightly, and involve drilling a hole through thick virgin wall that wasn't meant to have utilities pass through it. Hence why I'd want them to reuse the existing box.
      • kamak's avatar
        kamak
        Ambassador
        They will use a box in place of the existing one or if need be a slightly larger on. But all the digging and or conducting will be done by Telus, I would NOT attempt to do any of it. A waste of time , risk and money you don't need to bare. It's on them to get the fiber to and into your house. Their cost, time and risk. I'm sure it will be exactly where your Ethernet is right now.
  • NFtoBC's avatar
    At my house, they just pulled the fibre through the existing conduit instead of the old phone line.
    • polecat's avatar
      polecat
      All-Star
      Titanium kamak NFtoBC  Same at my place used existing conduit used old copper wire as a pull string and pulled fiber in. Only change was the box on side of house a little bigger with extra fiber coiled up inside for possible repairs later. fiber entered where the old copper wire entered. no new holes.
      • Titanium's avatar
        Titanium
        Organizer
        I would have thought that my home back in the pre2000s they would have been smart enough to put a conduit pipe. However this is not the case. Confirmed by my neighbor who used to install cable TV. The copper phones wires are just in a thick half inch black outdoor rubber jacket, burried direct in the dirt, no conduit, the plastic "conduit" pipe from the ground level to the box is only a riser, but it's not continuous once it touches a few inches into the ground.
        I wonder if I can dig around this riser pipe, and then have them bring the fiber up to it, and then snake the fiber into this phone riser conduit.
