yycbond
1 year agoOrganizer
DVR to modem connection issue
I am suffering with an issue with the connection from my telus dvr to the telus modem. Every 48 hrs the connection resets twice as below 13:22:31 Kernel event eth0 (Ext switch port: 3) (Logica...
1 year agoSince the equipment swap didn’t solve it and we suggested it might be due to too many connected devices, you could consider using a network monitoring tool to check for device traffic overloads or spikes that might coincide with the resets.
If you haven’t already, you might also try isolating the DVR on its own Ethernet connection, ensuring that no other devices are sharing the same port on the modem. Another option could be upgrading to a higher speed or more advanced router/modem model to handle more devices simultaneously. However, I understand it might not fully address the issue if it’s more complex.
- yycbond1 year agoOrganizer
Can you suggest a network monitoring tool that would be good for me to use for this issue I am having?
Thanks for the reply.
The DVR is on its own port on the modem and your mention of a network monitoring tool is the first time that has been suggested by anyone at Telus. I am on Telus 75 but since only one of the cable pairs coming into my home is any good I cannot go to a bonded service and higher speed (which I previously was on). Fibre is not an option since most of the community that I live in has been converted but not the portion where I am - and asking Telus on numerous occassions has produced zero responses to why that is. This concerns me since if the one good pair I have fails then my wifes work from home business will be down with no solution available>
After digging around in various posting sites I saw the mention of using port 1 on my modem in bridged mode and connecting a seperate router to that for use of all my connections (except the STB's since I believe they still need to work through the Telus modem directly (please correct me if I am wrong). So I have
a router ordered and will be trying that solution to see if that works. Again a possible solution not mentioned by Telus.
This problem has been escalated within Telus and your response has been the only one that has offered any possible solution rather than "disconnect your connections to see how many you can use without the drop outs"
