scoulter
5 years agoNeighbour
Does Fiber Internet SmartHome Wifi Router/Modem Cable Connection still work in Bridge Mode?
I have a fibre connection and a TELUS Wi-Fi Hub modem/router. If I put the modem into bridge mode, will the coax cable outputs still work? Thanks!
5 years agoBridging should only affect LAN 1. Try it. Worst case, you can return it to the default setting.
- scoulter5 years agoNeighbour
Thanks NFtoBC
Is there a manual somewhere for the modem/router? I'm a technical kind of guy and would love to read the actual documentation instead of experimenting.
- Nighthawk5 years ago
I haven't come across a manual for the wifi hub yet. The manufacturer doesn't offer one either.
