MNZS's avatar
MNZS
Friendly Neighbour
5 years ago
Solved
Creating separate 2.4 and 5 ghz wifi networks using Wifi Hub?
Is it possible to create two separate networks using the newer white Telus Wifi Hub? I was able to do this with my old T3200M. I can turn them on and off individually but I don't seem to be able to ...
  • NFtoBC's avatar
    5 years ago
    No, the Wi-Fi hub does not have the means to separate the 2.4 and 5 GHz frequencies, unfortunately. One work around might be to purchase a router which can be set up in Access Point mode to accommodate your 2.4 GHz devices, or possibly consider updating your smart devices.
