MetaBotNot
5 years agoFriendly Neighbour
Converting Basement Tenant to existing Pure Fibre
Dear Group, I am the house owner who has been using Pure Fibre for many years for Internet, Optik and VOIP Home Phone. The fibre comes into the main floor where the T3200M resides and is redistribu...
- 5 years ago
“Can Telus convert my Tenants service to copper by continuing to reuse the telephone lines or perhaps”
No. As Telus moves away from copper to Fibre, there is no means to maintain copper at the house. As you don’t want to share your current connection, your only option is to find the best means of adding a fibre connection to your apartment space.
MetaBotNot
Hi There,
thanks for the prompt reply.
I think Telus installed two fibre lines to my house. I am using one with a T3200M and MOCA boxes. Could Telus use the 2nd fibre line with a 2nd T3200M + MOCA boxes to supply internet service to my basement tenant? Telus could install the 2nd T3200M near my T3200M as well. I'm not sure if it is an issue sharing the coax with two different T3200M modem signals or whether it can be done. I understand the newer MOCA boxes have passwords so that may be a means separating our data on the coax. I would appreciate your thoughts.
5 years agoYes, you could set up a second network on the second fibre connection.
I have no knowledge of MOCA and passwords.
- MetaBotNot5 years agoFriendly Neighbour
Thanks for the reply and your help.
I just spoke to Pure Fibre Tech Support this morning and he also confirmed that I had a 2nd fibre available for use for the tenant. In my particular situation he said they would use the existing coax line going directly to the tenant's area with a MOCA box and a Wifi extender.
