imjumper
3 years agoNeighbour
Connecting Printer to Wifi
Hi, I'm helping my senior Father with connecting his printer to his telus modem. The modem is a T3200M, and the printer is an HP Envy 4500 I have the correct wifi password and have verified ...
- 3 years ago
I believe the printer requires a 2.4Ghz connection for wifi. It's possible the T3200M doesn't have smart steering enabled and has different SSIDs and passwords for the different bands. You may be attempting to connect to the 5Ghz band with the printer and that won't work.
Here is information on how to enable/check the setting:
FuzzyLogic
3 years agoI believe the printer requires a 2.4Ghz connection for wifi. It's possible the T3200M doesn't have smart steering enabled and has different SSIDs and passwords for the different bands. You may be attempting to connect to the 5Ghz band with the printer and that won't work.
