abh
1 year agoNeighbour
connecting Coaxial using MoCA
I would like to establish a connection between the modem in the basement and an upstairs room wired with Coax. Currently, the single Coaxial connector on the modem is already in use: connected to...
- 1 year ago
Yes, either way you need an adapter on the other end.
Signal strength is not an issue as far as the splitter if you don't buy a cheap no-name splitter. Another factor may be the quality of coax cable and termination in the walls.
abh
1 year agoNeighbour
If I used a Coax splitter, I would still need one MoCA upstairs to convert to Ethernet, right?
Also, wondering what effect that splitting would have on the signal strength to each device...
- xray1 year agoHero
