abh
1 year agoNeighbour
connecting Coaxial using MoCA
I would like to establish a connection between the modem in the basement and an upstairs room wired with Coax. Currently, the single Coaxial connector on the modem is already in use: connected to...
- 1 year ago
Yes, either way you need an adapter on the other end.
Signal strength is not an issue as far as the splitter if you don't buy a cheap no-name splitter. Another factor may be the quality of coax cable and termination in the walls.
1 year agoMoCA should support multiple adapters in a single network. This is assuming the coax lines are all connected together still. If they are not, you'd need a new pair of adapters if the coax is a direct line from where the modem is to the upper floor. That will get expensive. A high powered wifi access point on the main floor may be a cheaper option.
