JKB's avatar
JKB
7 years ago
Solved
Connect GE Smart Plugs 2.4ghz to Wi-fi smart hub
Hello, I have the Fibre optics wi-if smart hub and I cannot connect a GE smart plug because it says I don’t have a 2,4ghz. I see lots of fixes for the older version of the modems but not mine? I have...
  • NFtoBC's avatar
    7 years ago
    You should be able to turn Smart Steering off through the web interface. Access it at 192.168.1.254, and the password on the device. This will create 2 SSID, one for each band. You should then be able to add your devices to your network.
