JKB
6 years agoNeighbour
Connect GE Smart Plugs 2.4ghz to Wi-fi smart hub
Hello, I have the Fibre optics wi-if smart hub and I cannot connect a GE smart plug because it says I don’t have a 2,4ghz. I see lots of fixes for the older version of the modems but not mine? I have the Arcadyan Telus Wi-fi Hub? Any help would be greatly appreciated
You should be able to turn Smart Steering off through the web interface. Access it at 192.168.1.254, and the password on the device. This will create 2 SSID, one for each band. You should then be able to add your devices to your network.
- NFtoBC
