JeffC
3 years agoFriendly Neighbour
Can I mount my telus cable box behind my tv?
- 3 years agoIf your Optik box has an IR port on the back then all you need is the IR extender cable.
JeffC
My cable box is an older one, so definitely not the new Android box. I don't see technicolour or Arris marked anywhere on the box either. I guess the question should actually be, what do I need to do to mount the cable box behind the TV & have it function? I did a little internet research & it sounds like I would need an infrared extender cable. Perhaps I should contact Telus & inquire about the Android box.
3 years agoHero
- JeffC3 years agoFriendly NeighbourThx xray. My box does have an IR port.
- xray3 years agoHeroUnfortunately there are 2 types of 3.5 mm plugs for the IR extenders, mono (TS) and stereo (TRS). Make sure you get the one that matches the IR port on your box.
Thanks for the heads up! If I have a 50/50 chance of getting it right or wrong, 80% of the time I'm wrong! Lol
