mopudding's avatar
mopudding
Organizer
6 years ago
Booster WiFI signal works with Optk STB ?
My T3200 router's WiFi signal (in my basement) isn't strong enough for my wireless Optik STB (red signal indicator, not green). If I add a booster to run my wireless STB, will this work? This is to say I want to turn off the WiFi on my router and only have the booster offer a WiFI signal in my house?
  • Do you have a coax cable outlet in that room? If so you can get a MoCA adapter to run a network connection over coax.
    T3200M -> coax -> MoCA - ethernet -> STB
  • NFtoBC's avatar
    No. Unfortunately the Boost devices do not transmit the necessary multicast IP signal needed for Optik. Have you any opportunity to run an ethernet cable to the location of your Optik box, or move the T3200M closer?
    • mopudding's avatar
      mopudding
      Organizer
      That's unfortunate. I'm not able to run an Ethernet cable to my STB, nor relocate my router. If I added a second, 3rd party router to function as an acess point (plugged into Ethernet) that offered multicast, would this work?
