Dave_P
3 years agoNeighbour
Boost Wifi issues
Hello, I currently have a new Arcadyan Network Access Hub with a Telus Boost Wifi 6 directly connected to it. I also have a boost wifi starter pack (that I purchased before the upgrade and used on m...
- 3 years ago
If you followed these instructions, another option is to find the IP address of the Boost unit itself (from your main router admin page), and access the web admin page from that IP address.
Also, make sure you are connecting new Boost units to the Wi-Fi hub, and that they have been factory reset.
Ronster
I get Wi-Fi 6 is compatible, but what I meant was the original Boost pods cant be used to extend the Wi-Fi 6 network as it doesn’t support it. As well unsure if the new Wi-Fi 6 Boost could use the original Boosts to create a mesh. If the Boosts are just straight access points, maybe….
