Dave_P
3 years agoNeighbour
Boost Wifi issues
Hello, I currently have a new Arcadyan Network Access Hub with a Telus Boost Wifi 6 directly connected to it. I also have a boost wifi starter pack (that I purchased before the upgrade and used on m...
- 3 years ago
If you followed these instructions, another option is to find the IP address of the Boost unit itself (from your main router admin page), and access the web admin page from that IP address.
Also, make sure you are connecting new Boost units to the Wi-Fi hub, and that they have been factory reset.
3 years agoIf you followed these instructions, another option is to find the IP address of the Boost unit itself (from your main router admin page), and access the web admin page from that IP address.
- WaveDave993 years agoNeighbour
I used your second method with the IP address from my main booster repeater off of the router admin page, and used the WPS button to connect. I was FINALLY able to add my boost extension to my boost starter pack. Many thanks.
- colechapman2053 years agoFriendly Neighbour
could you walk me through exactly what you did because im having the same issue
