rajanjohal
5 years agoOrganizer
Boost WiFi Interferes with Optik TV
I recently added 3 Boost WiFi units to my network. Up until then I was using WiFi from a T3200M and WEB6000Q. Configuration is: 1) Nokia ONT --> T3200M 2) T3200M has some computers connected ...
- 5 years ago
The Boost units do not provide the multicast signal needed for Optik. You will either need to hardwire the Optik boxes, or return to the previous setup of multiple SSID using the WEB6000Q or the T3200M to provide Wi-Fi for Optik.
5 years agoThe Boost units do not provide the multicast signal needed for Optik. You will either need to hardwire the Optik boxes, or return to the previous setup of multiple SSID using the WEB6000Q or the T3200M to provide Wi-Fi for Optik.
rajanjohal
4 years agoOrganizer
I'm not using the Optik boxes via the Boost Wi-Fi.
The Optik boxes and Boost Wi-Fi are ethernet connected to a switch which is connected to a MOCA which is connected to the T3200M modem.
Are you saying that the Boost units and Optik boxes can't be hardwired in this manner?
- NFtoBC4 years ago
If the Optik boxes are connected by Ethernet or coax then they should work without problem.
I can’t offer further suggestions as to the Wi-Fi connections causing TV interruptions, but agree it is weird.
