Boywithdakicks's avatar
3 years ago
Solved
Boost Wifi 6, Rename Devices
We just got a upgraded wifi 6 Boost to our network, I love it and its futuristic looking lol, anyway since we also have the Boost wifi Pods, I can't connect this to the Connect app, Is there any way ...
  • FuzzyLogic's avatar
    3 years ago
    If you login to the Wifi Boost 6 web page (info should be under the cover of the base) and then go to Overview>Connected  Devices you can use Rename Device at the bottom of the screen to bring up a drop down menu of connected devices. From there you can change the name.
