Boywithdakicks
3 years agoOrganizer
Boost Wifi 6, Rename Devices
We just got a upgraded wifi 6 Boost to our network, I love it and its futuristic looking lol, anyway since we also have the Boost wifi Pods, I can't connect this to the Connect app, Is there any way ...
- 3 years ago
If you login to the Wifi Boost 6 web page (info should be under the cover of the base) and then go to Overview>Connected Devices you can use Rename Device at the bottom of the screen to bring up a drop down menu of connected devices. From there you can change the name.
FuzzyLogic
3 years agoIf you login to the Wifi Boost 6 web page (info should be under the cover of the base) and then go to Overview>Connected Devices you can use Rename Device at the bottom of the screen to bring up a drop down menu of connected devices. From there you can change the name.
- Boywithdakicks3 years agoOrganizerI also forgot to mention we own the B20T technicolor not the Arcadyan Technologies model
Because I didn’t see a overview section
