tedfroop
2 years agoOrganizer
Arris VIP5662W 4K Audio Problem
So, after a couple weeks of viewing 4k sports broadcasts (there are plenty this time of year) the Audio starts best I can describe it is skipping. 20 seconds of audio, 1-2 seconds of blank no soun...
- 2 years ago
If none of it works, the last suggestion would be to get a new HDMI cable or have the box replaced.
Also, when you said you have an older version of the STB, do you know what software version you had?
Thanks Kate, I initally tried all those suggestions as part of troubleshooting as a cable or port problem would seem the likely point of failure.
The same for swapping resolutions - to see if the problem was related to 4k alone and always the problem persisted until the optic box {singular -we only have one) was rebooted.
I have not seen the problem for a while, mind you I am not watching more than a few hours a week of 4k content now, so it has either been addressed or is related to a memory leak and some other process is refreshing memory often enough I'm not seeing the problem.
I do not know what the old software version was, I had at the time just replaced the box for PVR issues so the box, hdmi cable etc were all brand new.
Again sorry for the late reply. I have an anxiety disorder that affects memory and totally forgot about this.....
tedfroop
- the TV is up to date for software.
- the avr is up to date for software.
- The TV is on audio pass through via ARC/EARC so it has nothing to do with the audio stream.
- When the problem occurs I can watch the audio stream drop and resume on my AVR.
- Rebooting the Telus box temporaraly solves the problem. Once I watch about a week worth of 4k football, hockey and baseball the problem begins again.
- This problem started when I updated to the VIP5662W from an older version of the box.
- The problem does not occur with any other input. TV, Android Apps, Roku, Squeezebox, Chromecast, everything else has zero problems with audio - even though the Roku passes through AAC, AC3, DTS, DTS-MA, E-AC3, TrueHD, Flac, MP2 and MP3.
- Optik-Kate2 years ago
TELUS Team Member
Hi tedfroop, I reported this issue to our team and they provided the following recommendations:
- Update the screen resolution (720/1080): It can be swapped back thereafter
- Update the aspect ratio to standard definition: It can be swapped back thereafter
- Reseat the HDMI cable
- Try a different port on the TV
- try another audio cable (HDMI or Component) if you have one
- Reboot the STB while the TV is on
- Sequential reboot of STB's
- Try going to Settings - General - HDMICEC settings and select enable and see if that resolves this issue
- tedfroop2 years agoOrganizer
TELUS Team Member
Thanks for the update! Glad you are not seeing the issue anymore!
