tedfroop
2 years agoHelpful Neighbour
Arris VIP5662W 4K Audio Problem
So, after a couple weeks of viewing 4k sports broadcasts (there are plenty this time of year) the Audio starts best I can describe it is skipping. 20 seconds of audio, 1-2 seconds of blank no soun...
- 2 years ago
If none of it works, the last suggestion would be to get a new HDMI cable or have the box replaced.
Also, when you said you have an older version of the STB, do you know what software version you had?
Thanks Kate, I initally tried all those suggestions as part of troubleshooting as a cable or port problem would seem the likely point of failure.
The same for swapping resolutions - to see if the problem was related to 4k alone and always the problem persisted until the optic box {singular -we only have one) was rebooted.
I have not seen the problem for a while, mind you I am not watching more than a few hours a week of 4k content now, so it has either been addressed or is related to a memory leak and some other process is refreshing memory often enough I'm not seeing the problem.
I do not know what the old software version was, I had at the time just replaced the box for PVR issues so the box, hdmi cable etc were all brand new.
Again sorry for the late reply. I have an anxiety disorder that affects memory and totally forgot about this.....
2 years agoIf you temporarily disconnect the AVR and just use the TV speakers, do you have the same issue? Is there a software update for your TV also?
