Optikalist
4 years agoFriendly Neighbour
Any tips for better audio quality?
Just wondering if I'm missing a setting somewhere. My audio is terrible, dialogue is difficult to catch often run my sound bar 80 just so I don't need captions, meanwhile background noise and music ar...
4 years agoWhat I did was to disconnect my sound bar and TV, and turn the volume of the set top box to full (25?), then reconnect my sound bar / TV and set it to about 4. If I recall, I needed to unpair / reset the set top box so it became the sound source, then re-pair the two.
If you are trying to increase the audio of a low level signal, you are going to experience poor sound quality.
Optikalist
Set top is set to 25
- Optikalist4 years agoFriendly NeighbourSo I did grab another remote that's not paired with anything and adjust the volume down and up it seems as if there's no difference at all. It just seems to mute the audio on zero but between 1 and 25, I can't tell a difference thanks for the thought though
- WestCoasterBC4 years agoCPU AlumWhat sound bar do you have and what setting is selected on the audio bar dollby surround, stereo etc. I run a Bose sound bar and have no issues.
