Optikalist's avatar
Optikalist
Friendly Neighbour
4 years ago
Any tips for better audio quality?
Just wondering if I'm missing a setting somewhere. My audio is terrible, dialogue is difficult to catch often run my sound bar 80 just so I don't need captions, meanwhile background noise and music are overbearing and just trash quality. Upgraded my audio set up and it's the same...super frustrating, somebody please help me out, I don't want to hear it's compression....I see I'm not the only one complaining, and Telus keeps marking these solved...TELUS DO BETTER PLEASE!!
  • NFtoBC's avatar
    What I did was to disconnect my sound bar and TV, and turn the volume of the set top box to full (25?), then reconnect my sound bar / TV and set it to about 4. If I recall, I  needed to unpair / reset the set top box so it became the sound source, then re-pair the two.
    If you are trying to increase the audio of a low level signal, you are going to experience poor sound quality.
      • Optikalist's avatar
        Optikalist
        Friendly Neighbour
        So I did grab another remote that's not paired with anything and adjust the volume down and up it seems as if there's no difference at all. It just seems to mute the audio on zero but between 1 and 25, I can't tell a difference thanks for the thought though
  • KHR's avatar
    KHR
    Are there particular channels or shows where you notice it more than others? There is a very good chance that the audio quality is related to the programming provided by the content providers, and not something TELUS can control.  There was a very interesting piece by Vox posted to YouTube recently called Why we all need subtitles now. (link) It's 10 minutes, but an interesting overview of how sound recording and editing has changed over the years.
      Optikalist
      Friendly Neighbour
      Wondering if you would be able to provide the db ratings on the settop box from 1 to 25 on the volume settings
      Optikalist
      Friendly Neighbour
      If I stream through my Chromecast from let's say global it's perfect but anything through Telus sounds terrible, I've tried switching physical inputs, I won't accept it's the content providers issue for this reason
      Optikalist
      Friendly Neighbour
      It's across the board, it only improves when using a different input
