YvrTown
4 years agoFriendly Neighbour
Another "Why am I not getting 1.5 Gig speed?" question
Hi awesome internet friends. Just accepted increase to 1.5 Gig service, and agent said that he verified my equipment and no changes would be necessary for me to get the new speed. (Which, I shou...
- 4 years ago
YvrTown Wrote: There is no way I am going to get anything above 940Mbps as long as I have that **bleep** T3200, right?
You are indeed correct... The T3200M is equipped with a 1Gbps WAN port and 4x 1gbps LAN ports. Now at very best you can theoretically receive 1.25Gbps throughput on the WAN port in a lab setting, however you are very correct that the best single connection on this type of hardware and connecting will be a max of 940Mbps.
Now, if your Telus connection is provisioned at 1.5gbps, you may if all the additional hardware is capable of the speed achieve the advertised throughput utilizing the current offerings from Telus of either the Arcadyan NH20A Router, or the less utilized Nokia XS-250X-A (Seems to reserved for business installations)
I would contact Telus and see if they would be willing to upgrade your supplied hardware... Cheers...
YvrTown
Thank you! I've sent him a message to ask if he can stop by to set me up with the NH20A and Boost. I assume I will also need to an SFP+ too.
Again, I will let you know!
