ADSL-LTE's avatar
ADSL-LTE
19 hours ago
Ads showing as PIP on guide
I know it’s picky and I know they need ads to pay the bills but I have always turned to guide on in the past to block the same repetitive ads every 15 minutes. Now they show in a PIP in the guide mode.  Cmon I should have the right to decide what I wish to see.
1 Reply
  • TELUS_Support's avatar
    Yeah, that definitely is annoying ADSL-LTE .. maybe these below hacks can assist with that. Let us know what you think!
    Mute Auto-Play Audio: Check your set-top box or interface settings (usually under Accessibility, Audio, or Guide Display Preferences) for options like Guide Audio, Background Audio, or Video Preview. Turning these off will at least mute the audio from the PiP ad/channel window while you browse.
    Switch Guide Views: Look for a Grid View vs. Text-Only / Minimal Guide View setting. Simplified guide layouts often eliminate the PiP preview window entirely to fit more text on the screen.
    Quick-Mute Habit: If your remote has a dedicated mute button, tapping mute before hitting the Guide button keeps the repetitive ad audio from interrupting your browsing.
