Truenortheh's avatar
Truenortheh
4 years ago
Solved
adding a wifi6 router to my white telus wifi hub
hi there, ive tried looking through the forums but couldnt find any thing concrete.
i currently have optik tv and telus fiber internet.
the fiber goes to an ONT then the white wifi hub. can i simply plug the TPlink AX5400 router into the wifi hub or will that cause issues?
ive heard people bridge the telus wifi hub but i thought doing so would stop the optik tv from working.
any help into this situation is greatly appreciated.
  • NFtoBC's avatar
    4 years ago
    OOPs! It seems the ability to bridge Lan Port 1 has been removed from the menus. You can still set up a secondary network for Wi-Fi 6. Telus has provided a Wi-Fi 6 networking device in some markets, so if you can wait a bit, you might be able to obtain that device.
  • NFtoBC's avatar
    You can bridge the Telus device, but still leave the Wi-Fi on for Optik. You would use the second network for the rest of your network except TV.
    • Truenortheh's avatar
      Truenortheh
      awesome now i need to figure out how to bridge this port, the setting must be hiding some where.
      • NFtoBC's avatar
  • Hi there,
    If you didn't get help in the meantime, we recommend to contact our tech support for assistance on the compatibility. .
