DrPacman
2 years agoRockstar
2 years agoNokia ONTs don't have 10G ports on them. Are you sure you don't have a different device there? Do you possibly have the Arcadyan NH20A or the Technicolor FXA5000? They're the white square ones.
YYJMSP
2 years agoOrganizer
Black rectangular box says "Nokia" on the front. Back says model is XS-250X-A. Definitely a 10G port...
- Darren_P2 years agoOrganizer
I just ran a speed test and here are the results:
I checked and found the following.
- Raghbir2 years agoOrganizer
Hi. Thanks for including the screenshots. I have what you called "White Trash Can"; I cannot find anyway to find any diagnostics including network information that you included such as packets errors.
On your NH20T device, do you know if you can put this into bridge mode and disable dhcp and/or NATing? On the Telus hub, I put the device into full-bridge mode but cannot control dhcp or NAT and just wondering if NH20T can perform these tasks. I also ran my service without any of Telus hardware but them Telus could not support it when the network went down - nothing related to my network hardware.
Thanks, R
- YYJMSP2 years agoOrganizerAny idea how to login to the Nokia ONT that's in bridged mode?
