DrPacman
3 years agoRockstar
DrPacman
3 years agoRockstar
Thank You... Cheers...
tedfroop
2 years agoHelpful Neighbour
"Trashcan router supplied by TELUS. I will not discuss that device as I have little experience with it."
Trashcan is a good place for it......it is the reason why "downloading the Windows Speedtest App" is the only way to get accurate throughput numbers for your connection.
It institutes an oppressive QoS scheme that limits internal network speeds for Windows Home to about 45 mb/sec on my network. No way to do anything about it now that MS have decoupled QoS from policies in Win10 home. Transfer speeds among my *inux devices remains 100+ mb/sec which I found while trying to figure out why everything was so slow. Basically its "load balancing by limiting network speeds of QoS capable devices" and not intelligent balancing by traffic load, heavy handed "you don't need to go faster than X" oppressive balancing.
IE: even with a single Windows computer with QoS attached - your 1 Gb internet connection turns into 45 mb/sec.....
- frankw2 years agoOrganizer
I'm satisfied with the white trashcan router or "Hub" as Telus calls it, made by Arcadyan, and it works fine for me. Getting about 175 Mbps up/down on a ethernet connection or Wi-fi. Using an iPad 7 or 9 or iPhone 8 on WiFi, or wired connection to a 2011 Mac Mini, Telus PVR, 2 Sony TVs, and 2 Apple TV 4K boxes. Usually only using 2 or 3 devices at once, single person household, only use about 200 GB data per month.
The Hub is in the centre of my house in a ground floor closet and is connected there direct to fibre. The Telus technician was OK with letting me get dirty pulling the fibre cable 50 feet in from the garage through the house crawl space to the closet (Telus techs don't like or may not be allowed to go into dusty dark places, but I don't mind).
A Telus PVR and secondary non-PVR box for TVs are connected and one is running all day. There are two 1Gbps ethernet switches connected to the Hub and located in 2 rooms where various devices are connected. I would be interested in trying 1 Gbps from Telus but 180 Mbps is all I need for now.
- gri941 year agoFriendly Neighbour
this is insanely slow though i was sold a product with all the promises of speed. my shaw wifi router i still have here active i get 600mbps download and telus is at 150mbps down. sometimes as high as 200's in another room. that is insane slow. did i just go back to the 1990s?
- PaulB_1 year agoOrganizer
Which plan do you have?
- ab_lostboy2 years agoNeighbour
Seeing how the device itself is designed to handle the 1.5+Gb speeds (and thats where people have issues) I'd say your experience running the device at .18gb speeds isn't representational. Based on the speeds you're getting, a router from 2012 would give you similar service.
No doubt the white Telus Hub aka Arcadyan can deliver a lot more speed than my 175 Mbps. My Telus account is what limits me to that speed.
