mikhubb
2 years agoFriendly Neighbour
4K WiFi STB Won't Connect to Telus Boost
I have a Telus T3200M router/modem. I have an ethernet cable going to an Access Point (Netgear WNDR3700v3) in another room in the house and a further ethernet cable going to my 2nd Telus Boost at the...
- 2 years ago
Sorry I missed the bit about disabling the wireless on the T3200M. Have you tried using the WPS button on the booster to pair with the STB? There are self install guides here:
How to prepare for Optik TV self install | TELUS Support
FuzzyLogic
2 years agoThis may be of use:
Solved: How to connect wireless 4k box to wifi booster? - TELUS Neighbourhood
Depending on the Boost device you have there may be additional ethernet ports available on it. You could then use a wired connection to the 4K box.
- mikhubb2 years agoFriendly Neighbour
Thanks, but I had already read this post and many others and they don't truly address the issue.
