dsjstc
1 year agoFriendly Neighbour
Where to complain about removal of "wifi calling priority" on Android?
My house is a Farraday cage and I need to use wifi calling when I'm inside. I've got a Pixel 7, and I've enabled wifi calling.
However, if I get too near a window, the phone switches back to mobile calling, which has VERY poor quality. I want to use Android's "wifi calling priority" preference, but it seems that Telus does not permit it.
Where should I direct a complaint?
- SyaoranAll-Star
You can always put your device in Airplane Mode and then turn on WiFi Calling to prevent it from switching to cellular while you are home. Just make sure you remember to turn off Airplane Mode when you are not home.
- dsjstcFriendly Neighbour
fearnj, you have posted an idea with a very similar title, but it's specific to the USA, and all the replies have focussed on that. Could you try to edit your post title to indicate that it's USA specific? It would also be great if you added a link to my idea about enabling the preference.
Thanks, I have done so. Anyone following on, please upvote here:
https://forum.telus.com/t5/Ideas/Enable-the-Android-preference-for-quot-Wifi-calling-preferred/idi-p/155602 - TELUS_Support
Unfortunately, Telus does not currently support the "Wi-Fi calling priority" feature. However, we can forward your feedback to the appropriate team. You can also submit your idea directly at telus.com/ideas. Sharing your idea with friends and family may help it gain attention more quickly.
Related Content
Telus MyWifi App does not show me ability to turn on Guest Wifi - no "Guest Wifi" label
I would like to turn on a guest wifi network Online help shows the wifi tab in the mywifi app having a "Guest Wifi" label the user can click on But I when I go to that screen (pleas see attachment)...Solved8.8KViews5CommentsHow to access router web page of "Wifi Hub" model PVR65B? ( the cylindrical white one )
Tried the gateway address from a direct wired RJ-45 network link ( 192.168.1.254 ), but I get nothing. I don't remember how to access it, I know I did the day it was installed, I asked the technician...Solved5.9KViews1Comment
