cjarul
10 months agoNeighbour
Voicemail speed dial 1
My voicemail speed dial 1 is not working on my Android S24 phone. When I press and hold "1" on my phone it shows Add voicemail number? Then I click on Add number On the next screen under service p...
- 10 months ago
Thanks for reaching out! It sounds like your voicemail number isn’t set up on your new device yet. You can set it manually by following these steps:
- Open the Phone app on your Samsung S24.
- Tap the three dots (menu) in the top right corner.
- Select Settings > Voicemail > Voicemail settings.
- Under Voicemail number, enter your TELUS voicemail access number (6475804001).
- Save the changes and then press and hold 1 again to test.
cjarul
I did try this before. When I go into Voicemail setting, I can only see "Service provider". When I click on that, it says "My carrier". I am unable to change this or add any other number.
Related Content
- 9.2KViews8Comments
