cjarul's avatar
cjarul
10 months ago
Solved
Voicemail speed dial 1
My voicemail speed dial 1 is not working on my Android S24 phone.
When I press and hold "1" on my phone it shows Add voicemail number?
Then I click on Add number
On the next screen under service provider it is showing "My carrier"
When I click on this, I am unable to change anything.
Any idea how to change this?
  • Thanks for reaching out! It sounds like your voicemail number isn’t set up on your new device yet. You can set it manually by following these steps:
    1. Open the Phone app on your Samsung S24.
    2. Tap the three dots (menu) in the top right corner.
    3. Select Settings > Voicemail > Voicemail settings.
    4. Under Voicemail number, enter your TELUS voicemail access number (6475804001).
    5. Save the changes and then press and hold 1 again to test.
  • Retired telus telephone tech not telus mobility.  You don't press and hold on the number 1 it's just a tap. You can go into your phone settings to find out what is programmed and change it if necessary
  • I did try this before. When I go into Voicemail setting, I can only see "Service provider". When I click on that, it says "My carrier". I am unable to change this or add any other number.
  • C_Fun's avatar
    C_Fun
