makter
4 years agoNeighbour
Using Telus 4G LTE without B29?
Hi all - I'm visiting Canada soon and wanting to purchase a prepaid SIM to use for calls and data while travelling. Just wanting to confirm though that my phone will work without issues on the Te...
4 years agoIf you have an iPhone, you'll likely not run into issues. Band 29 is used in some rural areas but not many. Most Telus towers in BC/Alberta primarily use AWS (B4) for LTE. Band 2 and 5 can also be found on most towers. I haven't seen a single tower that is only band 29.
