rdllanes
2 years agoNeighbour
solutions to boost weak signal in a rural area
I have a cabin in a rural area where cell signal is weak to none. What solutions does Telus have or are there other alternatives?
- NFtoBC
There are cellular booster devices which amplify the signal. Of course, there're has to are sufficient signal to amplify.
- A-B
Community Manager
Hello. The best option for you may be Wi-Fi Calling which is through your internet service rather than the cellular network. This is optimal even for more urban areas where signal strength is diminished, and is easy to set up and use. Otherwise, you'd need to reach out to our Mobility team directly so they can look into the local tower(s) to see if there's anything that can be escalated or worked on.
