MajicSmoke
5 years agoNeighbour
LTE hub gets hot and resets
For the past 1.5-2 months now, our LTE hub resets randomly. The case is fairly warm when it does. It seems to happen whenever someone tried to download or update something. Has anyone else had this p...
MajicSmoke
It sits on a shelf, nothing around it. There's no vents for any kind of airflow on it that I can see.
That's why I'm thinking of modifying the case so it does get some air.
5 years agoHero
Modifying the case is not recommended. You could do more harm than good, especially on devices with antennae which may depend on the case design to work properly. Mobile phones are a perfect example of that.
