pomakis
4 years agoNeighbour
"air duct cleaning services" phone calls
For the last few months I've been getting unsolicited phone calls from "air duct cleaning services" almost daily. It's always from a different phone number, so I can't block them. I keep asking them ...
- 4 years ago
I think these offshore companies use an automated dailing system that transfers to a person on the first ring. Call Control kicks in before the first ring so it will never transfer. If they are manually dialling it would be very time consuming and inefficient. In that case I would make it even more time consuming for them. Say "Can you hold while I check my furnace to see when it was last cleaned?" Then put them on hold until they hang up.
polecat
4 years agoAll-Star
pomakis I assume you use the do not call list as i do i renew it on occasion. Also do the reverse lookup and from there you can report spam & robo calls. I had on really bad one so i kept doing the reverse thing for about a month and it finally quit. Middle of night calls they received lots of nice words from me.
- pomakis4 years agoNeighbour
How does one perform this "reverse lookup" of which you speak?
- polecat4 years agoAll-Star
pomakis Google reverse lookup where you can lookup a persons name from the ph # or Ph # from the name. Look over the page and you will see a place to report telamarketing numbers. Can't be sure it helped me but they stopped after period of time. Maybe it was the airhorn used.
Related Content
"Your TELUS Home Service account has been modified" - but I did not initiate this!?!?
I got two emails yesterday Aug 11 from Telus claiming that my home service agreement has been modified (Agreement Date : August 12, 2025 12:38:27 a.m. UTC (Order Completed)), yet I took no such actio...Solved324Views2Comments
