ithero's avatar
ithero
Friendly Neighbour
1 year ago
Telus Fiber + Static Public IPs: NAH must not be in Bridge mode?
I keep hearing over and over again from Telus on-site techs and support agents that the Network Access Hubs will not work with Static IP addresses if set to Bridge Mode and they should be set to Router Mode instead.
Help me understand how the WAN traffic is expected to hit my Enterprise Firewall directly over the static public IPs configured on its WAN interface, when the upstream Telus NAH is running in the Router Mode with its LAN side configured as a Private Network 192.168.x.x, and handing off private IP addresses to the downstream devices?
There should be something configured like the Bridge or IP pass-through on a dedicated port, but there is NO WAY I can connect to a firewall over the public IP when it sits behind a NAT!
  • ithero's avatar
    ithero
    Friendly Neighbour
    With the help of bimmerdriver who shared this reddit thread with extra details, I believe that now I've got a working theory.
    In "router" mode NAH has a dual personality:
    (A) it functions as a typical home router, handing off pivate IPs to LAN devices via DHCP (192.168.1.0/24), and NAT-ing internet traffic between WAN and LAN zones.
    (B) at the same time it functions as a plain router between LAN and WAN subnets with no NAT in action.
    In "bridge" mode NAH runs as a bridge on a dedicated port. On that dedicated port the WAN/LAN zone segregation collapses into a pass-through bridge. The device connected to this port will acquire a DYNAMIC public IP from ISP.
    • ithero's avatar
      ithero
      Friendly Neighbour
      Let's review in detail each mode.
      (A) Router mode with NAT: a typical home router.
      NAH gets a public IP address from Telus on its WAN interface e.g. 50.50.50.50
      On the LAN side NAH has a 192.168.1.254 gateway address and provides private IP addresses to its clients: 192.168.1.1-250
      NAH routes internet traffic between WAN and LAN while doing the Network Address Translation which effectively hides the LAN zone from direct access from the internet.
      (B) Router mode without NAT: meant for static IPs and direct reacheability of the LAN zone from the internet.
      Just like in (A), NAH gets a public IP address from Telus on its WAN interface e.g. 50.50.50.50
      Telus provisions a Static IP subnet for the customer e.g. 100.100.100.2-6 range and the gateway 100.100.100.1.
      NAH's LAN interface is configured with the second gateway address: 100.100.100.1 (in addition to 192.168.1.254).
      The downstream client (enterprise firewall) is configured with static IPs: 100.100.100.2-6.
      • ithero's avatar
        ithero
        Friendly Neighbour
        Now the LAN interface of NAH is configured with 2 different IP addresses and both act as gateways for their own sets of clients:
        The DHCP clients will reach internet via the gateway IP 192.168.1.254. This traffic will be NAT-ed/masquaraded with the NAH's WAN IP 50.50.50.50 and continue towards the ISP. Everything originating from the client's network will show source IP as 50.50.50.50.
        While the clients configured with static IP 100.100.100.2-6 (the firewall in our case) will reach the gateway IP 100.100.100.1. This traffic also will be routed to NAH's WAN 50.50.50.50 and continue towards the ISP.
        However, the big difference is that the 100.100.100.0/29 subnet will never be NAT-ed/masked with the NAH's WAN IP 50.50.50.50. Instead, the WAN IP 50.50.50.50 will be just another hop on the way to ISP. And vice verso. This makes the 100.100.100.0/29 subnet visible as source and directly accessible from the internet.
        The only other pre-requisite that needs to happen for the statics to work, is provisioning of the 100.100.100.0/29 subnet on the ISP side, so that their systems know that the subnet is available via the 50.50.50.50 path. This can be easily implemented via static routes on the ISP backbone. Otherwise the internet will not know how to reach 100.100.100.0/29.
        Lastly, the bridge mode. The problem about the bridge mode, apparently, is that once configured, the LAN/WAN zones collapse into a pass-through bridge and we end up with no interface where we can set up the gateway 100.100.100.1 for our static IPs. In such scenario the the gateway must be created on the next hop device on the way to ISP. But that's a totally different design approach that Telus isn't doing in the first place.
  • What is your configuration? Who is providing the static ip address(es)?
    • ithero's avatar
      ithero
      Friendly Neighbour
      Telus of course. LAN > Enterprise Firewall > Telus NAH > Fiber > ISP.
      5 Static IP addresses from Telus.
      I am assigning them to the Firewall's WAN interface.
      Branch offices and Remote users must be able to establish VPN tunnels with the Firewall (VPN Gateway) over those IP addresses.
      This means that the Network Access Hub must transparently pass-through the packets.
      Telus claims that NAH must be set up in Router Mode for the static IPs to work. Router Mode means NAT.
      • Butter-Biscuit's avatar
        Butter-Biscuit
        Replying so that others can find this (hopefully you figured this out already).
        The Telus network access hub does in fact need to be in router mode for static IPs to work. Your device will get a 192.168.1.x IP if you have them set to DHCP. If you set the static IP that Telus gave you, the NAH will do something internally and then you will have a public static IP without NAT. It sounds counterintuitive but that's how it works. Bridge mode will only get you a dynamic public IP.
