RobG3987
2 years agoAmbassador
Guide display adjust
When I view the guide I see 6 rows, with the 6th row partially cut off.
I press the Channel Up/Down button to scroll to the next 6, since the previous last line was cut off,, I have to press the Up button to go up/down in order to see what the previous cut off row was.
And repeat each time I do a Page scroll.
Can you adjust the guide layout to fully display all 6 rows?
Currently my display setting is set to Auto.
- RobG3987Ambassador
Well, well,,, that did the trick đ.
The hardest part was finding the TV remote.
Thanks Optik-Kate ,, one less thing for the developers to do.
Cheers
Rob
- Optik-Kate
TELUS Team Member
Hi RobG3987 , I played around with my TV's setting when it comes to aspect ratio, upon selecting "screen fit" on my Samsung TV, the 6th channel shows fully on the guide now!
- Optik-Kate
TELUS Team Member
Hi RobG3987 , thanks for flagging this. Confirming I can see the 6th channel on the guide being cut off. The intended design is to show the 6 rows fully. I will forward this to the design team to see if it can optimized.
