scoulter's avatar
scoulter
5 years ago
Does Fiber Internet SmartHome Wifi Router/Modem Cable Connection still work in Bridge Mode?
I have a fibre connection and a TELUS Wi-Fi Hub modem/router.
If I put the modem into bridge mode, will the coax cable outputs still work?
Thanks!
  • NFtoBC's avatar
    Bridging should only affect LAN 1. Try it. Worst case, you can return it to the default setting.
    • scoulter's avatar
      scoulter
      Thanks NFtoBC
      Is there a manual somewhere for the modem/router? I'm a technical kind of guy and would love to read the actual documentation instead of experimenting.
      • Nighthawk's avatar
        I haven't come across a manual for the wifi hub yet. The manufacturer doesn't offer one either.
