Reply
I need a puk code my sim card is locked!!! Help
Posted
Re: I need a puk code my sim card is locked!!! Help
Posted
Hi JulienSincennes, a client care representative can help you with that if you dial 1-866-558-2273 from a line other than your mobile. I recommend calling from a different phone, as it allows you to easily test if the PUK code works while you are on the line.
21
Posted
i can't i don't have a another phone available with me
Posted
Greetings 21!
I highly advise contacting our support via Twitter (https://twitter.com/telussupport) so that our agents can retrieve the PUK code from your account.
Posted
the telus office is closed!!!!!!!!!!!!!!!
